I've got a pair of "trail quality" turn signals and I am having a terrible time getting my rear drivers side blinker to operate. I have functioning headlights hi/low, brake lights, reverse lights, right side blinker front and rear. When I pull the hazard switch everything works but the drivers rear. When I turn my left signal on, the indicator clicks then stays solid. Front turn comes on but stays solid but nothing out of the rear.
From all the searching I did I ran seperate grounds from both housings to a bare spot on the frame. I had to rewire the pin connecters to match oem but everything is right. I even ran a new clean rear harness but still happened. All bulbs have been replaced, fuses replaced
Voltage at the rear driver turn is .29-.31 compared the the normal voltage at the other lights.
Any suggestions on what to check next?
Thanks in advance
Thanks in advance
