Rear Hatch Supports?
Went ahead and ordered these. Doesn't seem to be a consensus pick so no biggie as it's just a simple lift strut. The McMaster Carr seem like a good option, but I don't feel like fiddling with with fitment (even though it seems pretty simple). $28 direct fit with free shipping and a "lifetime warranty" :rolleyes: for the win today! Thanks for the replies...if they suck, I'll let you know!
Good luck. They are just struts, either they work or that bank vault door of a lift gate hits you in the head.
FWIW, I have the struts from Cruiser Yard aka Jason aka @arcteryx
I have the front and rear struts on my 92 and 93. Will also order them for my son's 92 when the time comes. I've had them for over a year and they are a direct fit and work well. Even in cold weather.
They almost work too well. You have to pull down on the hatch in order to get them to work. Which I think is a good thing.
Do they lift the gate above the factory height of horizontal?
I believe the stroke length is 18.39, which would be horizontal...I can confirm once they arrive. At 6' tall, I don't really need any extra lift.
Boy I think so. I'm almost positive. I will snap a pic in a few when I get done at my daughter's show choir.
I don't have a tape measure with me but it appears that they open the hatch about an inch or so higher than level. I can put a tape on the extended stroke length when I get home.
Not to make it MORE complicated measure from pivot point to pivot point on the strut it self. The factory measures 18 and two little lines:hillbilly:
That picture was taken at -6 degrees. I didn't push up on the hatch but I think it actually has a little more room to go up.
-6°:eek: is there a shrinkage factor I should consider
I wanted to go to the lake tomorrow because its going to be 74°:beer:
McMaster Carr ones have been great on my rig for last few years. Hatch opens up higher, no more hitting head!
This is a link to the ones that fit the 80. Plug and play.
McMaster-Carr
Russ
What's the Force number you used or recommend? There are a variety of options on this bad boy.
Read the thread about it that was previously linked. If I recall, it is 90 PSI.
