Just curious how the others on this thread have moved forward...
May not be very helpful, but may be accurate. Yeah this "light surface rust" truck of mine has been driving me nuts recently. Such simple little jobs (brake pads) have turned into such big expensive time consuming projects. You are in NH, what'd you do with your dust shields?
Personally, I would be inclined to take off the radiator cap, drive a new truck under it, then go home.
That type of stuff is now gonna plague you for the rest of it's life.
Sorry, not very helpful.
$1800 axel, 2014, 59k miles, with diff.
Might be a better option considering how rusty my axle is.
220K. They were pretty loud, and the passenger side was in the process of failing when done (had spit grease on the ABS sensor leading to ABS light)At what point are others changing wheel bearings though?
220 that220K. They were pretty loud, and the passenger side was in the process of failing when done (had spit grease on the ABS sensor leading to ABS light)
220k, that sounds like a fair number. Wheel bearings wasn't on my list of anything that would require attention in the near future. I hadn't heard of them failing on a 200 til now so was curious what the fail mileage range was. @cruiseroutfit did your bearing actually go bad down at 125k, or did you just change them because of the back plate rust issue? I'm all for preventative instead of waiting for them to fail, i just don't want to change them if i still got another 75-100k miles i could still roll on them.220K. They were pretty loud, and the passenger side was in the process of failing when done (had spit grease on the ABS sensor leading to ABS light)
220 that
I'm at 125k now, so hopefully i have some good life left on mine. My back plate issue at this point is just 1 out of the 4 with the rust issue (that i see). It's only issue is slight rattling offroad, but i think i can do a temp patch job with a thin sheet of metal and a dab of jbweld just to hold it together.
I do agree that when i eventually do change them it'd make sense to do the bearings and that RAK200 rebuild kit at that same time. Also, I'll probably casually look for any deals if they pop up on a salvage low mileage complete rear axle and maybe go that route instead. My axle is pretty rusty itself, so i wouldn't mind changing the whole thing out.
, well that ain't good. I'll read through the threads, i really appreciate the links. I wouldn't consider mine a heavy rig compared to others. I have a dual swing bumper, roof rack, but no drawers. It is my DD but does see a decent amount of trail use. That being said would you just consider this in general a 125k mile preventative maintenance item if you have a 200 and like dirt? Does the RAK200SF kit include everything i'd need besides the new back plates? Any guesstimates how many hours labor a shop should charge for that if i decide not to tackle myself? Or maybe better way to say it would be how many hours labor would you charge for that job including the back plates?Catastrophic failure, bearing grenaded at 120k
Builds - Project Fauxverlander 200 Series Land Cruiser Build Thread
Thanks! We had a great race (see the Canguro Racing thread) The 200 was most spendid. Other than @bryson treating every seat like a napkin it was perfect ;) Hey now, it's not my fault that your new seat covers are so soft and absorbent...:flipoff2:forum.ih8mud.com
We've seen others fail/get play in similar range, predominantly on heavy 200's that see a fair bit of trail use (along with the Canguro 200), for example here is another:
2013 - 100K miles - Bad Rear Left wheel bearing?
I picked up our 2013 cruiser with 97K miles in late September and have put about 8k miles on it since then. Since the first day I got it, I felt a clicking/dragging type noise clearly coming from the left rear wheel when driving next to a wall or building with my driver side window down...forum.ih8mud.com
Here is my current axle. If i can find a low mileage salvage for a decent price that already has the back plates, I'd prefer to go that route.$1800 axel, 2014, 59k miles, with diff.
