Thank you. I'm taking a long break from mods but a locker is tempting. Without the locker, would that put the job at around $2k ?
Mmmm, around that yes.
Geez. That pricing is ridiculous. I'd pickup a low mileage whole rear axle assembly for that price from a wrecking yard. Probably doesn't even need R&R and would be a drop in.
2008 Toyota Land Cruiser Parts - Splash Shield - 4770360090
cheap!!!! - and not sure why but these listed are not hundreds of $'s
you got that rightThose are front, quite different from the rears.
How many miles on those Kurt? Climate?
You guys are freaking me out. I'm gonna try to wax mine this weekend.
<----- (already did my frame)
did I miss the reply on if the tundra splash guard or backing plate would fit with no issues? looks to be a bit less expensive if it can be a solution.Yes, spray em with wax. There are many nooks and crannies in that area that need protection...
This issue is really troubling.
@cruiseroutfit
Kurt, can these brake dust shields be easily inspected for this rust and corrosion?
Is the inspection as simple as going under the truck? Or do I need to pull the tires? Or remove even more things?
Thanks in advance for your advice and insight.
Alfred
