YIKES!This is when you worry...and don't ask me how I know:
Sent from my iPhone using IH8MUD while navigating gnarly trail. Typos are inherent.
The result of the faulty torque wrench was that I started to round the head of the drain plug and the fill plug a bit. They still come off, so that's fine, but I'm going to replace them now before they get too tight in there.I went this route so I didn't have to worry about rounding off that drain bolt on a rock:Anybody know the part # for the rear diff's drain plug and fill plug? Can't find it in the history of this thread, if mentioned.
Had the pleasure of finding out that my brand new Kobalt torque wrench (3/8" drive, 20-100 ft-lb) is either faulty or was never calibrated correctly. On the 20 ft-lb setting I was able to tighten my LC's lugnuts, and the wrench never clicked. Back to Lowes I go....The result of the faulty torque wrench was that I started to round the head of the drain plug and the fill plug a bit. They still come off, so that's fine, but I'm going to replace them now before they get too tight in there.
Use the search function.....it is a subject that has been covered a couple hundred times.how do you remove the fill plug if it's rounded off?????
Got it fixed today. Got the fill and drain plug from the dealer, and got my faulty torque wrench replaced. All happy. Thanks allI went this route so I didn't have to worry about rounding off that drain bolt on a rock:
OEM Magnetic Differential Plug Kit
Toyota Magnetic Differential Plug Kit (DPK-1)absolute-wits-end.com
That Valvoline squeeze bag makes the front dif fluid change SO MUCH EASIER!!! No pump needed. Used on my 2000 LC. I like royal purple, but that doesn’t come in a squeeze bag yet. Unfortunately.View attachment 2633509
Is this ok gear oil to use to replace the front and rear differentials? Also I know they’re different brands but will it be ok to mix? I have 4 quarts is that enough to do front and rear?
Total game changer. No muss or fuss with messy pumps. Transfer any remaining fluid to a surviving pouch to avoid wasting the smallest amount. I almost look forward to fluid changes.That Valvoline squeeze bag makes the front dif fluid change SO MUCH EASIER!!! No pump needed. Used on my 2000 LC. I like royal purple, but that doesn’t come in a squeeze bag yet. Unfortunately.
this guy annoyes the hell out of me but this video explains what to use
bsically GL-4 for manual transmission GL-5 for differentaials and Transfercases
What no love for Scotty or Chris fix. Lol.I love AMD. He is the only YT car person I can watch.
Great channel, but too much of an OE-fluid evangelist. My rig is doing just fine with Delvac 75w90 in the T case, 80w90 conventional in the diffs, and MaxLife ATF in the trans.What no love for Scotty or Chris fix. Lol.
He’s alright direct to the point about toyota fluids.
The internet + fluid talk = hell hole.Great channel, but too much of an OE-fluid evangelist. My rig is doing just fine with Delvac 75w90 in the T case, 80w90 conventional in the diffs, and MaxLife ATF in the trans.
I actually do like the AGM batteries, but have a voltage booster in my gloveboxThe internet + fluid talk = hell hole.
Delo ESI in my diffs and Delvac in my t-case. Sorry, AMD.
I disagree with his recommendation to run AGM batteries in Toyotas or Lexii not set up with that charge profile.
But I would use him for my service if for some insane reason I lived in Chicagoland.
I saved a bag…when I baselined the LX, Mobil1 was $3/qt cheaper than Valvoline, so I bought the Mobil1 and transferred it with the Valvoline bag!That Valvoline squeeze bag makes the front dif fluid change SO MUCH EASIER!!! No pump needed. Used on my 2000 LC. I like royal purple, but that doesn’t come in a squeeze bag yet. Unfortunately.
I’ve been looking at these. Just connect some tubing and have at it.I saved a bag…when I baselined the LX, Mobil1 was $3/qt cheaper than Valvoline, so I bought the Mobil1 and transferred it with the Valvoline bag!
