- Thread starter
- #141
Nevermind. It was determined that if a big enough meteor were to hit the spindle, in just the right spot, it *could* break.
So, they got another pass.
Sent from my C771 using IH8MUD
Most spindles that "do" break---snap at the upper weld / heat fatigue area over time. Given that you have boxed the spindle....you would be much better off with a very limited penetration weld in that upper high fatigue/load area. Not only is there no need for a big weld/multiple welds....but its actually working against the life of that spindle. The weld simply needs to hold it vertically and let the strength of the boxing act as the main horizontal load bearing element.
Cold worked steel is not good for welding applications since the heat will just make the metal lose it's strength (near the weld-basically releasing the tensile stresses of cold working) that was gained through cold-working. Hot worked metal is slightly weaker but more ductile and better suited for welding applications. Hot rolled will be cheaper and keep your bumper costs down while actually ending up being just as strong at the weld as cold rolled.
nope- most spindle breaks are "stress/ fatigue" related........and all occur at the uppermost weld which is weakened by the aforementioned reasons. The horizontal loads on a bumper with a swingout of 24"length with a sizable tire/accessories is fairly significant when compared to the effective yield strength of mild steel. whether you use cold rolled or hot rolled- once you hit it with heat from the weld- you are effectively reducing the cold rolled strength back to hot rolled- at the weld.
Its a pretty easy fix given your boxed design at the spindle area which looks good. You really want the boxing to be doing the work relative to the horizontal load...........so just lay down a bead to "hold" the spindle to the boxing and let your design do the work.
Is this 3/16th?
What's the story on the pink and purple princesses Jeep?
Hahaha.
Bumper looks good, too.
Any word on making a high clearance version for the rock junkies???
