Rear axle service
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
Getting geared up to do the rear axle service and wanted to know what was peoples take on the e-brake shoes. What condition are you finding your e-brake shoe in? Should I just figure on replacing the shoes because it’s apart (100k on the Cruiser)?
Does anyone check the run-out on the axles? I have seen some post on the axle splines distorting but nothing on the axles getting twisted or bent.
Phil
My pads were fine, the e-brake just needed to be adjusted when I had my brakes looked at.
E brake pads were fine at 100k or so. They're really only going to show wear if someone along the way accidentally drove off with the parking brakes on. I greased some of the internals a bit (very sparingly) and scuffed the drum and pads lightly with sandpaper, then hit em with brake cleaner and put it together. Both before this and after, I can hold my truck stationary in drive headed down a steep hill with just a moderate pull on the brake lever.
DougM
Phill, when I did mine I asked C-dan the same quesiton...he said he's never sold a set.
Mine were fine as well.
I did mine a few weeks ago and asked C-Dan the same question. Basically got the same response as Safado.. I have 99k on mine and the shoes still have plenty of meat left on them..
Just make it a practice not to drive with the e-brake engaged, and you will never have to worry about it... :flipoff2:
Oops, sorry Cdan....... ;-)
DougM
