I searched - I Promise.
Bought the parts from CDAN to do the Rear Axle Re-pack. The FSM seems pretty straight forward except it lists a bunch of SST tools. Do I need anything special (like the 54MM I needed for the front)? I am thinking I need the SST for the lock nut (See below). Are there any other special tools I might need.
The link in the FAQ refers to a write-up by KlunkyChris that is no longer there. The pictures are also mssing as well.
Just want to make sure I have what I need before I tear into it. Based on the pre-load, I believe I should wait to get the SST.
The below is from a thread about rear axle pre-load,:
Then Beowolf stated:
So Based on this alone, I assume I need to get the SST. With the SST, can I set the pre-load via the method Landtoy80 described, or do I need a tension gauge.
Thanks
landtoy80 said:The Haynes manual says to adjust the preload
"Install the brake disk and hold it in place with 2 lug nuts. TIghten the locknut to 43 ft lbs while rotating the hub ass. to seat the bearings. Back off the locknut just untill it can be turned by hand" and so on.
Is this what you are talking about with the SST?
kurt
Beowulf said:Kurt,
On the FF rear axles the locknut is round so there is no way to torque it with any type of normal wrench, socket, channel locks, etc. The locknut has 3 holes in the outer surface. The SST has 3 prongs that go into these holes.
Here is a fuzzy image but you'll get the idea. Borrowed the pic from the OTC tools web site.
-B-
Thanks
