like this?
I mounted the heavy duty relay that fires up my Tmax compressor (built into in draw unit at back) as it previously had battery clips on it, and I want to add a tank eventually, and have it hard-wired not portable.
I also discovered that if you remove the top middle socket from the swicth panel, it fits
perfectly over the opening knob, and allows you to twist it just far enough to open and close.
im going to need to re-label the switches, the only one Ive connected up so far is the rear door spots below, but I've got 9 more fuse ways and 5 free switches here now.. roll on more gadgets
I liked the right hand cubby hole for wiring as it's too small for much else, and fully plastic inside, no metal for cables to accidentally touch at some point. Its still got room for the solar controller in there on the right too.
