Rear 3rd member + e-locker used pricing? (1 Viewer)
GXO
GXO
Moderator
Woodstock, GA
Website
gxor.org
What is the current used private pricing on a stock e-lockered rear chunk?
I have a line on one for a certain amount and can swap that sucker right into my 91 using the e-locker control from http://www.inchwormgear.com/ ($75)
What's the word?
Thanks!
Dan,
I have not tried to purchase a used locker rear diff. I can tell you that a new one lists for just under 1,300 bucks (off today, can't tell ya to the penny ::) ). Often junk yards try for half the new price. I would say anything over about 650 bucks is getting kinda close to what you could get a brand spankin' new one for (if ya know where to shop ;) ).
Aside from housing mods I am not too intimidated by the install.
the price I have lined is way less than of your lowest price...may be worth it!!
Thanks!
sor only wanted $450.00 last i checked. :eek:
Guys,...guys,
All I said was anything over 650 was a bit much, I wasn't trying to sell one for that ::) . I don't do used..... ;)
I'd say 450 was very fair. :banana:
[quote author=Bradass80 link=board=2;threadid=4980;start=msg38183#msg38183 date=1062776609]
[/quote]
Where did you find it, on the SOR web site? I was looking on their site and couldn't find it.
They are $500 at Cruiserparts but they are out of stock :'(
If I could get a low mi one, I then wouldn't have to rebuild mine plus I would get a actuator that is not in 3 pieces 8)
kurt
It would be nice to go in with someone that needs the diff but the actuator and split the charge :-*
Kurt, I may have a line on a salvage FZJ80, will send owner your way if it all goes through.
I have a new rear elocker actuator sitting in my garage. :flipoff2: Not going to use it since the portals are going under this winter.
Anyone want or need? :D
I called them when i was quoted $450.
Dan
Doesn't your 91 have a SF rear end? For some reason I though the e-locker required a FF rear end.
Otherwise I would love to put one in my 55.
Jared
The e-locker can be installed in a SF axle, I do not know the specifics. Theferg is in the middle of doing something along those lines.
D-
I don't think the electric locker can be installed in the rear land cruiser semi-floating axle [could be wrong, whats new :flipoff2:]. The toy semi-floater requires the c-clip to hold the axles in place - so the locker will not fit.
In fact, I'm getting like Junk, and I know it won't fit ;).
It does fit the FJ front FF axles.
- lock axle in locked position, slip in housing
- replace a couple of diff studs, which need to be a little longer
- install longer splined, short side axle, i.e. front, short side axle from a 70 series, Downey, CV Unlimited, etc
- wire up the actuator, use factory actuator controllers / relays, or cable attachment
Joe
The Downey kit is for 40 and 60 to add 80 third member using a cable to lock the diff. The kit comes with axle, cable and a block to mount where the actuator goes.
Maybe it won't work on a SF. That wouldn't be the first thing Downey sells that doesn't work.
kurt
Well, the secret was I am trying to get a FF rear end w/o locker and the chunk with the locker to mate together.
pricing is looking good too...who knows!!
[quote author=landtoy80 link=board=2;threadid=4980;start=msg38300#msg38300 date=1062796310]
Is there a blue light price?[/quote]
If that was directed towards me, yes, there is a blue light price. Send me an email or PM and I'm sure we can work something out so you'll soon have a locker in the rear. :D
[quote author=cruiserdan link=board=2;threadid=4980;start=msg38163#msg38163 date=1062772151]
Dan,
[/quote]
Dan Is the under $1300 for the compleat thrid member; gears,bearings,case,actuator ect assembled ready to install?
