Hi all, doing some work on a '66-'67 FJ40 with an F engine. Took the manifold and carb off for a rebuild and because the manifold had an apparent leak.
Rebuilt the carb, cleaned up the manifold and got some new gaskets and a new carb insulator.
I'm trying to re-install the manifold and there are two studs coming from the head that go into the near and far ends of the manifolds. The rest of the manifold is held on with bolts and clamps that go into the head.
When I set the manifold in place on those two studs from the head, the holes on the intake manifold do not line up with the holes on the head. They are about 1/8 to 1/4 inch too high.
Could this be the wrong manifold for this engine that was swapped out by a PO? Anyone have pics of what the '66-'67 manifolds should look like? (one barrel carb with the three piece gasket).
Any help appreciated.
