- Joined
- Dec 12, 2006
- Threads
- 79
- Messages
- 3,628
Uphill
Much respect to the brotherhood40 to save the day, jump start worked.
Thanks all for help, we hope there’s no more issues on the way to moab.
Glad you made it. Looks like a ton of fun. Kinda jealous.
This is completely off topic, but is that a 3rd brake light I see? Kinda like that idea for safety reasons. When you have time, can you share more about that?
Thanks for finding that @FJBen !!!He’s posted about it in his thread:
Builds - Rub A Dub Dub, Pablo's Got A New Tub!!! - https://forum.ih8mud.com/threads/rub-a-dub-dub-pablos-got-a-new-tub.80054/page-15#post-13052283
Short story, from a 70 series.
We did ultimately drop the fuel from the tank and start over.I drained mine recently due to water. Siphoned most out then drained the rest. Under seat fuel tank, at least my 73 has a low point drain plug accessible under the truck, drain into a 5 gallon bucket.
That would make sense - fewer people buying the ethanol free fuel...Water stops up the fuel filter. I was running the ethanol free high octane but I think the station tank was contaminated. That tank is slow to turn over compared to regular.
Thank you! I will add Wesco Offroad to the list, he was nice enough to stop and pull me into Parachute.Try Mike G at MetricOffroad….970 270 3332
Keiths Garage… 970 462 2686
I purchased just about all the 5/16 fuel filters that the local O'Reilly's had.I once ran my 72 on a 1 liter IV bottle of gas taped to the antenna because the fuel pump went out. I run an electric fuel pump now and have a spare. That doesn't look like enough rust crap to plug a filter. However the paper element will not pas gas if wet with water. Couple of bottles of yellow gas dryer in the tank. Have several filters to swap in until the water is gone. The filters will dry out and be good for next time you get bad gas.
The dizzy was firmly in place. My guy had set the timing for max vacuum after the header install. IIRC, we should be at 12 degrees.Make sure the distributor hasn't slipped timing? That 10mm holding screw *can* loosen and cause similar symptoms when timing gets way off.
Thanks @Godwin , we did this Thursday morning after an unplanned stay in Grand Junction. This seemed to do us some good, until it didn't.Pull the drain plugs on the bowl and flush with carb cleaner. May help some until the issue is fully resolved.
TIL - good stuff, thanks!I'm assuming OEM carb. The pair of drain plugs are below the sight window and are 14 mm heads. Access is easy. There is a copper washer with each one. Don't lose those. You shouldn't have leakage after pulling these out and reinstalling, there's no substantial fluid pressure in the carb. Pull the drain plugs, use a can of carb cleaner with a straw and flush out the fuel bowl.
I did do a few "let off the throttle while going down the road", not vaccuum in the same places, but...give it the ol rev and choke by hand rebuild.
take the air cleaner off, rev it by hand, block off the venturi with the other hand, open throttle fully while choking it out.
Thanks! Mine is a early '78, so I have small-cap, electronic distributor.If this is a points distributor, have they been checked? Lots of times points issues can seem like fuel delivery issues.
Can you say more words about this @Engineer8000 ?And the coil going out can seem like fuel starvation too.
There were definitely times she ran well.
But there were plenty of times she didn't.Hell bent for Moab - - YEE HAW !!!![]()
