RE: Advice from FJ25 'ers' for my 1964 FJ40
I like it.
Advantages: You can show off splattered mud with that color, and bird poop will hardly show.
If you try a white bezel, you can change it back if you think you missed.
Found this Dulux Paints Chart on eBay recently. Circa early 1960's Toyota.
I bought this for the White Samples and Codes.
I'm thinking 'Alpine White' for the Bezel?
The later Koito sealed beam headlights were put on other Japanese vehicles. I find them on Subarus, Corollas and such. Maybe yours were put on other early Japanese vehicles and a search there will turn some up.
4 w/s hinge bolts. two side bolt holes below that look like mirror mounting. that's where my 45 has the mirror
my wag
1 is dimmer switch
2 are where the wiring harness passed through with a big grommet
3 is throtlle pedal mt
4 master cylinder
5 steering column (i'm guessing this was a floor shift?)
6 is about where the fuse block would mount, but seems close together
7 ignition
8 turn indicators
9 lights wiper choke
10 windshield hook
11 int light
radio is not original not sure on the rest, no 40 series here to look at, so i'm going off memory
