RE: Advice from FJ25 'ers' for my 1964 FJ40 (1 Viewer)
What do you use to cut your replacement sheet metal pieces on the bench (pieces that aren’t straight so a shear is a no-go)? Because of access issues when cutting the bad spots out on the rigs’ components I use a Dremel with cutoff blade, sometimes my dewalt grinder with same, and occasionally a jigsaw (rarely there’s room). Cuts are ok, but not precise (square, straight, etc.). So the bench cut replacement piece is cut with same tools, but that’s somewhat a PIA (slow, imprecise to match the imprecise original cut, lol). Was wondering about a nibler? (If not obvious I’m not a sheet metal worker, just a hacker 🤪).
Very thin Angle Grinder Blades
What, 55 years ago? 😛
......a bit more progress.
I'm not confident that the 'Shell Ivory' on the Bezel is the right Tint? It doesn't look White enough.
Thoughts?
