Random misfire question. (2 Viewers)
Buda, Tx
Howdy folks,
I could use some help from the brain trust. I have a 98 100 series as well an '03 V8 4Runner, that immediately after an oil change, I got a 2,4,6,8 misfire code. With a better reader I'm also showing an O2 and catalyst code. I'm not one to believe in coincidence and I don't want to just throw parts at it. I thought I figured it out at first when I pulled the coils, they were original, and they all had a crack down the side. Replace all with OE coils. Plugs were replaced 10k ago. I figured it would be something simple but I’m stuck. Any thoughts or suggestions are appreciated.
Thanks,
Mike
Did you pull the plugs to inspect them? Are they OEM plugs. If possible, post a picture of them. I would be concerned if they were heavily fouled or showing heat damage on the porcelain.
I did pull the plugs they were clean.
