- Thread starter
- #81
Once home I decided I had to figure out why the rig wouldn't get out of "green mode" as it should have hours ago. The DTC tool is a small blink code reader that is very simple and only gives codes not real values, but it's all I had. I was showing several codes after running the diagnostics including a low system voltage code.
That didn't make any sense but I pulled out the multi-meter and started running every test I knew. I wrote down a ton of voltage readings from batteries 1 and 2, running and not running, under load and at rest. Alternator, starter voltage, headlights on and off, blah blah blah. Nothing seemed out of whack.
I decided at this point I needed more help. I'd just buy a code reader/scanner. But regular automotive scanners aren't plug and play with the Ramjet. It's based on a marine engine and the harness is too. After googling my brains out I needed a Rinda Techmate scanner!! GM RamJet crate engine diagnostic and tuning tools OK, not for that price.
Next step... boat service center.
The guys at Sunset Marine in Oceanside were great. It took a bit of convincing that I truly needed their boat motor scanner to connect up but alas they did. I didn't even ask what it would cost I just wanted it done...
Low voltage and most intriguing... zero hours.
(EDIT: The other codes that popped registered were: 34-MAP Low Voltage, 51- ECM Calibration Error, 81-Throttle Actuat. TAC Fault, 81-Fuel Pump Circuit Low, 5 Volt Reference Voltage Fault, TAC Error No Tac Reply).
What the F%$ck!? That made no sense. The computer is resetting every time I start the motor...
