- Thread starter
- #41
Once all the primary wires were hooked up the ground wires were next. There are 3 ground wires all pretty close together on the harness. The instructions are pretty adamant about placing each of the 3 grounds in seperate locations. With the limited range of the wiring I was glad to find that I could place two on the rear of the head on the passengers side and the other on the drivers side. It was at this time that I realized how important it was for me to have left room to get to the rear of the heads. I used short bolts and threaded them into the heads attaching the ground wires.
Now that the wiring harness was installed all that needed to be done for the electrical was to re-attach the battery cables but since they were still removed from the engine compartment that would have to wait. I still had to plumb all the cooling system hoses, add coolant, oil, and tranny/transfer oil, plumb the fuel lines, attach the vacuum lines, remove the distributor and prime the motor with oil, install the plug wires, and wire up the batteries and starter. Then I could fire it up and see if it would run.
