Hi all,
Hopefully there's still a few SBC guys out there who haven't converted to EFI yet! I'm finally back to working out kinks in carburetors after 3 years with no engine!
I have been chasing a "disapearing fuel" demon for years now, across two different quadrajets on two different V8's and two different fuel pumps.
Things I've tried:
1. I know quadrajets have a notoriety for leaking from the welch plugs, but both of these carbs have had their plugs epoxied. The first, (a very early Qjet) I drilled, tapped, and epoxied myself. The second was a much newer version of a quadrajet (ModQuad) from a reputable builder (Sean Murphy Inductions) who epoxies them as part of the build.
In both cases - with epoxied plugs on a 283 SBC, and later on my current 350, the bowl is still empty in 24-48 hours.
2. Next I thought that MAYBE I had a syphon issue, where gas was being pulled back out of the quadrajet and draining back to the tank. I installed an anti-drainback check valve in the fuel line right by the carb to ensure this doesn't happen. It still happens...
My QUESTION:
Where is my gas going? My only thought is that my under-hood temperatures may be getting high enough that I'm boiling/vaporizing the gas in the carb, causing it to leak out the jets when the engine is shut down. This would purge a lot of gas before it cooled, and maybe leave a small enough amount in the carb that it could evaporate normally afterward...
That said, my IR thermometer only shows the carb getting to about 120-130 degrees. The carb is already sitting on a thick (1/4") base-plate gasket. Looking down the throat of the carb a few minutes after shut-down, I don't see a trickle of gas or anything that looks like leaking. I'm not running into any vapor lock or hard start issues - but it might have a BIT of a rich kick when I first start it after it sat in a parking lot for a while (small puff of black smoke).
Could 130-140 degrees be enough to boil/vaporize 10% ethanol gas? The usual "go-to" to resolve this a phenolic spacer under the carb, but given the lack of insulation on the hood, I feel like radiant heat would get the carb to 140 degrees pretty quickly even if it isn't sitting on the manifold.
Is there anywhere else in a Quadrajet gas could be escaping that I'm not thinking of?
As always, thoughts, opinions, and advice are much appreciated.
Things I've tried:
My QUESTION:
