Nice setup but it wouldn't work on an e-locker axle.
I don't understand why it wouldn't work.The elocker motor would be on the other side and shouldn't make a difference
10" is what I have been told, mine is on backorder.
The way to measure for ram throw length is drop a plumb bob off of your tie rod approximately where you want your cylinder to mount, with properly adjusted steering stops, go full lock left, make a mark on the floor, go full lock right, make a mark on the floor and measure between them. I think you will find it is between an 8" and 10" ram.
Thank you for the info.I did measure and came up with 10".But I was told that I shouldn't go with the max length because of the stress it would cause on the birfs at full lock/turn.I thought that was strange.I mean,I understand that there is more stress at full turn but I wouldn't think that you should limit the turning radius,just avoid hard throttle at full turn.Right?Does that make sense?
Bingo. FYI, they say it should be in stock in a couple weeks.Any chance this is the ram you have on back order?http://www.surpluscenter.com/Hydrau...1-5X10X1-DA-HYD-CYL-SWIVEL-EYES-9-7258-10.axd
You want the ram to be your 'steering stops', not those at the knuckle. If the ram's stroke exceeds the movement range of the knuckle, something is going to give, and it probably won't be the ram.
I am going 10" ram after hearing from several folks. Wrench and Mr. Jits have been very helpful answering all my silly questions.
I bought a adjustable mount for the tie rod end from , I am not planning on changing from stock (well I have a Slee tie rod) but not planning on changing to high steer arms.
http://www.polyperformance.com/shop/Synergy-Outer-Diameter-OD-Tube-Clamp-p-1727.html
I will test it to see if it hits the stops on the knuckles or the ram first. I agree the ram motion should limit the knuckle movement.
No Worries Onur. There's nothing like getting a little zinxed as motivation to work on the 80. I need to do bunch of stuff any way. Parts are sitting around all over the garage and in the house (for other small little PMs and stuff) that I've been putting off and they need to be installed. I needed a kick start.
I went through Kirk's thread again since I remembered after you mentioned about Kirk and found the following pix. This is exactly what I was thinking just couldn't put it in picture. So thanks for pointing me to the right direction
Is this a 10" ram? I am having problems finding the best place to mount my ram. Also, with this setup, can you pull your pumpkin out still?
