- Joined
- Sep 9, 2004
- Threads
- 200
- Messages
- 12,476
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #61
Ready to start on reassembly now.
Cheers
Cheers
Contact your local 70 series scrapyard
I have that sitting on the shelve
-Oil pan plug is a mess. JB welded up. I will be replacing the oil pan.
I've seen that on quite a few different south/central american trucks (diesel and gas). Any theories as to why this is so common?
Hello,
Looking good.
Like the 1HZ, the 1PZ engine is reliable and repairable with limited means.
Being an LX, does this PZJ70 have the 4H button on the dash? I could not tell from the pictures.
Tinted windshields are a common sight in Central and South America. Probably a shield from the sun, like the sun visors found on Australian Cruisers. That place receives almost as much sunlight as Australia throughout the year.
OEM on that market maybe?
So when you got to def$*kify the last guys work you need to get inventive! To much silicone and a bit of rust, no brass hammer and punches and this job becomes a chore. Helps having a good friend next door to my shop who has about $2-million in machine shop tools!
Cheers
All you need is a pipe to bust the birfield from the shaft. Or a 2-3lb hammer.
And two 90520-27091 snap rings.
It's simple stuff. I'd recommend swapping the sides if you are serious.
