Pushing up the ac drier out of harms way
Outsane
Supporting Vendor
San Mateo, CA
Website
solvefunction.com
Here is how I relocate the ac drier so it's no longer ready to hit a rock. This is prep for a @Delta VS Bumper but useful for most bumpers. I have done this on 3 vehicles.
I use my hand like a mandrel so the Tube's bend where I want. I believe the drier should be kept vertical, it also will catch debris in the line.
Be sure to watch where the lines feed through the sheet metal so they don't rub and create a hole. Alternatively you can buy parts to relocate the drier next to the battery. It's about $200 in parts.
While doing this keep in mind the turn signal…the connection to the dryer will be behind it and push it out slightly if your not mindful of it
Somebody who had my truck before me got it mounted up beside the battery. I was always thankful for their efforts but I have to put cardboard between it and the battery bc they fit pretty tight, I’d be kinda disappointed in the results if I paid $200.
Just pushing it up is the better move.
While doing this keep in mind the turn signal…the connection to the dryer will be behind it and push it out slightly if your not mindful of itI
When I did this originally I drilled a hole in the turn signal. With the delta bumper it will be eliminated
I have been thinking about how this would all work for while pending my AC rebuild in the next couple weeks. My brainstormed idea for turn signals was to gut the housing and use one of those trailer style oval LED signals fit into the factory lens. I haven't taken any measurements, but it felt like a promising idea. Trimming the housing is probably less work though.
If I can find my old housing I can send it to you, even less work.
Eh, I appreciate it, but it's probably not worth the trouble of shipping it. I imagine it would take about 30 seconds to clearance that with a tiger's paw. I'm still thinking I might do the LEDs if I can find some that'll fit the lenses.
Agreed. Pushing it up is a better solution for several reasons.
1. No need to purchase parts (Receiver Drier, lines, etc).
2. Process takes just a few minutes to achieve much better clearance than before.
3. Moving the drier up a few inches is adequate for most off-road applications (save for extreme rock crawling).
4. Keeps the receiver/drier in basically the same area as engineers intended (more on this below).
Comment:
In our A/C systems....I would wager the receiver/drier is the least understood component (with respect to its purpose and function).
I think most understand that the Receiver/Drier has a filter and desiccant inside. The purpose of the desiccant being to capture any moisture that might be present in the system. That's pretty much all the 'drying' function the unit does.
But the canister also serves a 'receiving' function and this is where location and VERTICAL orientation are important.
I've seen examples posted in the past where the owners have turned the canister at a 45° angle to achieve more clearance. Even seen one example where the canister was turned horizontal (completely defeating the function of the unit).
The Receivers function is to accept mostly liquid refrigerant from the condenser. The refrigerant enters through the top, goes down through the filter/desiccant elements and collects in the bottom of the canister. The receiver is designed to hold excess refrigerant/oil when not needed by system demands.
But it also finalizes the condensing process of the refrigerant so that you only get LIQUID refrigerant going from it to the expansion valve. As for location. Toyota wisely chose to move it from behind the battery to a more accessible and 'cooler' spot (though they went a little too far IMO).
This allowed for easier installation, a larger canister and a cooler area to prevent the refrigerant from trying to 'boil off' in the hot confines of the under hood area.
Just be aware that moving the R/D can result in some amount of performance loss and weigh that against your gains.
IMO moving the unit UP a few inches is the best solution and performance loss would be negligible. Relocating to behind the battery is something that even Toyota decided could be done better.
Could you say a little more about this? I was going to try this mod this weekend, since it hanging down seems like asking for a problem on trail. I have a slee shortbus front bumper and the drier sticking out has always bugged me.
I just finished listening to your podcast re shiny side up. Major bummer, but this too shall pass. Thanks for sharing your story.
91s 92s and some 93 came with them from the factory with them mounted up next to the battery.
Interesting I didn’t know that. Maybe it’s always been there, I don’t know.
It’s chillin, and I won’t be harshin it’s mellow anytime soon.
Makes me wonder how long the short bus has been on this truck. Slee is usually pretty fastidious about such things. Makes me wonder if he doesn't offer a better solution now? After all, Slee does sell an extra piece of armor for the ARB, which leaves the D/R unmoved but well protected.
My 1990 hdj81 had it up by the battery.
My aussie '93, it hang7s down
I moved mine using all OEM used parts except the dryer itself.
It was very inexpensive and works well.
No worries about kinked lines or rubbing holes in the lines.
Plus with my bumper the only way to get it out of harm’s way was to bend it to a 45 degree angle.
Nothing wrong with pushing it up if you can get it to clear and keep it vertical.
I put the shortbus on a year ago, last spring. It had an ARB prior. The PO appears to have moved the drier up 3/4" already (above the lip in the bracket). I don't think it is a huge liability, it only sticks out an inch or so. I've driven up and over a lot of ledges with it like this. I'd just like to copy Outsane to put it behind steel, to reduce the likelihood of crushing it.
What is the possibility of replacing the dryer with a sorter version and pushing it up as well? I could have sworn I had read someone used a Camry or Corolla unit in its place.
OK, not quite as bad as I'd imagined. Knowing me, it would be the first thing I'd smack it on though.
Long term, moving it out of even a little harm's way is a good idea.
Definitely something one wants to address.
I have seen one get hit and let go on the trail.
Sent everyone running for fresh air not to mention what it does to the environment
