Can u bolt up A PTO factory winch to any fj40 maybe a stupid question. I have a PTO winch on a 79 fj40 and wanted to see if it could be used on early model fj40 thanks for taking the time if u know the answer
As far as I was told, the PTO gears were factory installed in xfer cases through 1976, which was the last year that a PTO winch was an factory option in the US.
My '78 had the spacer, and I had to pull the trans/xfer case pair to install the gear. If you do that, it's a good time to replace the xfer case input seal and check everything inside anyway.
