@beno... I was asking your thoughts on the availability of PTO winches on HZJ75s... and/or what a PTO gearbox would be used for on an HZJ75 otherwise.
PTO winches were quite common on JDM 60/73/74 series trucks, we got plenty here in NZ. The shipping would likely be $$$ though.
With the shear pin upgraded they're a great winch.
Cheers
Clint
Yup, 15yrs ago I got three PTO boxes and winches for Nissan Patrol/Safari out of NZ.
I fit one to my 83 Patrol rock crawler. Built a custom winch cage and modified the front crossmember and shafts to suck the winch all the way back. Worked excellent and no longer was the PTO winch sitting way out in front. The awesome thing about the Patrol PTO winch is it used a f/w hub for the freespool. So if you ever bust a hub in the field you got a spare on the winch. In addition to this it was set up, by Nissan mind you, so that you could put a big wrench on the winch and spoil it in by hand, or if you are totally screwed you could winch the truck by hand as well.
Great thing about a PTO winch is you can run it all day long and it will never get hot.
Here is a pic or two of it modified and set up on the Patrol. Sorry not the best pics but you can see the winch is sucked all the way back to the grill. I actually deleted the valance panel to get it all the way back.
View attachment 2080076View attachment 2080077
Cheers
Had a pto on my old bj40, loved it until I broke the yoke fiddlin around. Strong as the engine itself, pretty cool. Tended to rattle around a bit tho. Heard stories of cow cockies rolling down hills attaching the pto to a slasher. as long as your long ranger fuel tank is not in the way. Couldn't imagine putting one on my hj75 tho. If it came stock it is quite a bonus. Have to use them regularly like the front wheel drive, shaft slops out if not used.
