cruisedeisel
Toyota's for life
has anyone done this to a 3b yet?
how about water methanol to cool her off?
yah, but have you tried it yourself with a proper injection system?
or is it just book knowledge you are going by?
i know it works for power increase first hand and have yet to see first hand any engines that have died from the properly meetered addition of propane.
i will challenge you to provide a soley diesel based engine with the same results for the same $$$ investment as a PI unit useing the same engine base.
ANYTHING you do to a diesel will shorten its life span when you have an idiot at the wheel.
Most of the information you'll find online is from manufacturers or vendors of such systems, hence most are heavily biased.
Your statement is incorrect, the fumigation of diesel engines with propane or other fuels has been studied for years, the available data on line goes back to the early 1900's when the diesel engine was developed. Your lack of understanding concerning the proper use of the technology does not negate the performance of the technology.
Here is one sample of many I found on the net, to avoid your misconception that "most information you'll find online is from manufacturers or vendors" I located this as a study done at a University as a project to test the systems and their use with test results.
What is Fumigation? A fumigation system injects a gaseous or liquid fuel into the intake air stream of a compression ignited engine. This fuel burns and becomes a part-contributor to the power producing fuel. While alcohol and gasoline may be used, gaseous fumigation seems to exhibit the best overall power yields, performance, and emissions benefits. LPG (Liquified Petroleum Gas) or CNG (Compressed Natural Gas) is used. The fumigation process is divided into major fraction and minor fraction fumigation. When more than 50% gaseous injection is used, it is known as major fraction fumigation. Minor fraction fumigation is under 50% gaseous injection. One after-market fumigation component supplier, Algas Corporation, using 20 to 25% fumigation rate, reports excellent performance benefits and reduced target emissions. One test for a 1984 6.9 liter diesel engine in an F250 chassis showed a 64% reduction in NOx and 45.2% reduction of particulates. CO was almost unchanged. However, total emissions of hydrocarbons in grams per mile increased.![]()
Graph courtesy of Algas Corporation, a Division of Precision General Inc.
History of Fumigation Rudolph Diesel's 1901 patent mentions the diesel fumigation process. Not until the 1940's were there any commercial fumigation applications. Cooper-Bessemer introduced large, big-bore, stationary engines which ran on 95% natural gas and 5% diesel. Since then other manufacturers have used fumigation to boost power output. Fumigation has been successfully used in agricultural machines for many years. To date, Texas and Colorado have accepted fumigation as an alternative fuel.
Benefits For nonstationary variable RPM engines, variable ratio fumigation is more effective than fixed rate fumigation. As a result, engine load and fumigation rates are matched. Reduced NOx and particulate emissions are the most outstanding benefits. Minor fraction fumigation yields significant (up to 25%) gains in smoke-limited torque gains. There are other technical non-pollution related gains. Tests show reduced exhaust temperature, reduced crankcase solids, reduced injection service and longer acceptable crankcase drains. Diesel exhaust odor is also reduced.
Your anecdotal evidence (Evidence, which may itself be true and verifiable, used to deduce a conclusion which does not follow from it, usually by generalizing from an insufficient amount of data.) proves a predisposition to believe the fumigation process does not function properly.
The misuse of any technology can damage an engine.
I look forward to your engine tests with Crushers. Let the games begin!
Jim
