Jim
That information you have posted does not include any testing, only regurgitation of a kit manufacturers claims.
Can you post a link to the source?
As Gerg has said, I've run my own tests and found detonation at levels of 0.4% by volume with LPG (a propane/butane mix).
There is only one situation where manufacturers allow gas fumigation, the qualifier is the gas must not form any condensate (liquid) at 250 bar.
LPG fails this test, the only gases that will pass is methane/CO2, i.e. natural gas.
MAN Diesel - Engine Programmes
If a gas passes the 250 bar test then it won't self-ignite in a diesel engine.
Try this, the gentleman has been in contact with me via email.
If you have doubts please contact him directly he has sent me several links to studies and companies that have done Fumigation.
Franz Hofmann, Alternative Fuels, Biography
Here is a direct quote from one of his emails.
"Practically any diesel can use propane fumigation, the trick is to limit the amount of propane used and have backup controls to prevent overfueling. There are many "companies" that sell basic regulators and venturi mixers that simply ingest fuel with no controls.
I am not impressed with some of these products but there are others that I think do a pretty good job. David Shea at Technocarb has a very nice setup: Home
There are a few others too, ACME Alternate Fuel Systems- PRODUCTS has a good following. At one time, SuperChips had what I thought was one of the best, Superchips DPI Digital Propane Injection Fuel System but I havent kept track of them for several years now.
If you noticed a trend, its these systems have a fairly strong compliment of electronic control, I dont think there is a place for a strict mechanical system.
Hope this helps some;
Franz"
Your claim of testing propane fumigation fails to supply the very test data you ask me to provide. Something about wrestling with pigs comes to mind.
For fun I have included this link it's from India.
http://indjst.org/archive/vol.3.issue.3/mar10amar-4.pdf
I have found many sources to prove out this technology, it is pointless to try and convince you with source, data, facts, anecdotal evidence, or for that matter just plain common sense, in your world your facts are the only facts.
I have not sent you more links nor will I, there are so many on this subject available if you really wanted to know you would have already found them(I found studies from 7 different State Universities, 4 different countries and at least 12 different State run projects), since you choose not to do the research and demand I provide the proof and assert if I can't than I must be wrong (back to the pig thing) find it for yourself.
The person I referenced in my link Franz Hoffman should provide proper certification that this technology is proven if he can't I know I can't.
Now when are you going to take up Crushers challenge?
Oh well one more attempt.
Here is one on CNG, I know you will claim it's not propane but if you bother to read it there is a surprise, good luck.
http://wvuscholar.wvu.edu:8881//exlibris/dtl/d3_1/apache_media/20636.pdf
I have run several engines on propane fumigation, you stated you tested an Isuzu engine at idle and it knocked so you discontinued the use, if you study the concept of propane fumigation you will discover it isn't at its best at low loads, but you already knew that.
Jim
