- Thread starter
- #141
nuther day, nuther rust hole patched...
Finished fabricating the various patches for the front passenger body mount. I am using thicker steel than original, and of higher quality. Most of it is new, but a couple patches are old sections of my 67 Mustangs Floor Pan. Good stuff, that old stuff! Ended up doing a lot more rocker panel work than I thought (really? more work than you thought? You are kidding, right?)
Door sill rust got cut out
Inner Rocker patches tacked in.
Front Rocker/ lower cowl fully installed
A nice look at the new toe board section from underneath. You can see the rocker patches here too. I will test fit the body mount tomorrow, then finish weld those patches, and move on the the next section.
When I was cleaning the quarter, so I could weld the corner back on, I found it. Rust. Rust that did not get sandblasted off. I had thought that the lower quarter, from the wheel lip to the corner had just a couple little holes I could spot weld shut. No. There was so much rubber undercoating poured into the quarter, the sandblaster could not really get it. When I cleaned it off, it was not a couple holes. It was 90% gone. Very disappointing. Another little setback. But. BUT! It did give me a good round of practice with panel shaping, more advanced than the straight floorpan/door sill ones I did last week. Contours and curves and bends! So, pictures of the days work. Two lower quarter panel patches.
