Builds Project Lockjaw-1973 Fj40 on Tons (2 Viewers)
I assume you welded together a split tail gate and did that? Did you use the split hinges and modify?
Yes Sir.....it was the original barn doors and upper hatch. Welded a piece in the center to make it a wider piece and into a tailgate. Just moved the hinges and cut the one down that is pictured in the center to make it look normal. The latches are from a early model Fj45.
This is the same idea I have eventually on mine. Thanks for confirming it works
Started with an idea not knowing someone else had already proved it. Check at @matzell
