Builds Project "Devil Frog" - Isaac's '69 FJ40 (2 Viewers)
And to feed the beast
I'm impressed. Do you order the MS ECU with the right connector for the harness or do you have to use some sort of daughterboard/motherbaord adapter, programming, mapping, or some other sparky term I'm not familiar with to ensure all the pins on the connector go to the right components on the MS ECU?
there are MS DIY PNP kits available with the same connector for many common ECUs
http://www.diyautotune.com/catalog/diypnp-c-75.html?osCsid=1fbb29c25b50ff544fd679bd2eaf39a7
There is a main board that is common for all the MS DIY PNP kits, and then an adapter board that makes it PNP for your particular harness. I got the kit for the 52 Pin Nippon Denso ECU, there were instructions to build it to run a 5MGE and 3SGE, but not a 3FE. I had to map the appropriate signals to the respective pins using this diagram from the 3FE FSM:
This was the mapping
Edge Pin Connections
Main Adapter
IAT A17
CLT B10
TPS SIG B4
O2 SENSOR B2/B11
VR IN + B13
VR IN -
OPTO IN +
OPTO IN -
VR2 IN +
IAC
TACH OUT
FUEL PUMP A16(VS)
INJ1 C4
INJ2 C8
12V * A2
12V
12V
VREF
5V
SG A12
SG B1
GND C10
GND C05
GND
GND
GND
IGN1 A12
IGN2
WLED
ALED
Main Adapter
IAT A17
CLT B10
TPS SIG B4
O2 SENSOR B2/B11
VR IN + B13
VR IN -
OPTO IN +
OPTO IN -
VR2 IN +
IAC
TACH OUT
FUEL PUMP A16(VS)
INJ1 C4
INJ2 C8
12V * A2
12V
12V
VREF
5V
SG A12
SG B1
GND C10
GND C05
GND
GND
GND
IGN1 A12
IGN2
WLED
ALED
Oh man, us sparkys really love this crap.....glad I ain't doing all this work though!
Fuel tank is ready to go
Tub is off frame
Supra injectors are in, and the rail has been converted to AN-06 for compatibility with the Aeromotive fuel system.
Could one use supra injectors with no other mods? How much of a difference is there?
You need a programable ECU for any injectors other than the OEM speced
Got it thanks. About to send mine to RC to be rebuilt, was just curious about other ways to polish these tractors
Injectors alone will not get you increased performance. You need to increase air flow AND fuel flow somewhat proportionately. Have you done anything to increase airflow? There are lots of options, cams, displacement (2F bottom end), port and polish, forced induction, desmog. The factory EFI system should be able to support a modest increase maybe 15-20%.
I got the tank in, but it is not a nice secure fit, pretty much rides in the skid plate. Evaluating options for snugging it up.
Somewhat of a rolling chassis
Some progress from my body and paint guy:
Clutch and tranny installed
My implementation of Jstncse's air elocker conversion
Too cool, I love the operation of that valve
A preview of my paint choice
Turbo oil feed and auto meter oil pressure sender installed
