Build Project "Devil Frog" - Isaac's '69 FJ40
You are only running one 80 locker, so I assume you used the segment if the 80 harness fir the rear std pinion locker?
Correct.
Front elocker in. I picked up knuckle alignment SST and pull scale (thanks Ali and DanS!). Time to bottom front axle up now.
No hesitation, no doubt ... you will love it.
Time to get back at this project, got these chromoly hub gears to complement the longfields. Axels should be pretty bullet proof now.
Got the hub locker reassembled with the new gears
Found this bad boy on CL and just picked on my lunch break. I know the 40 is in pieces and a winch is the last thing I need now, but Ash convinced me to snatch one of these if a good deal came up. Just needs some line and a remote. I'll get some synthetic line eventually.
I may have an extra remote that I am not using if you are interested. I will need to dig it out of my stash of parts.
Vince
Vince
Sweet! Let me know
Nice score dude!!!
Rollin' again and got an external gas too. Need to get the tub off and to media blast.
More scope creep, surprise surprise. I just picked up the mechanical bits that will yield a 3FTE:
turbo kit
This is a proven system, but I will run the electronics differently than Akarilo did. It will work well with the Megasquirt and LC1, I will just need some bigger injectors, and with my bumped up compression ratio I am going to pursue water/meth injection and a knock sensor. That should allow 6psi of boost for ~250bhp at the crank.
3FTE in the works, next I need to source some 7MGE injectors to fuel this beast properly.
I built my Megasquirt. I used a Nippon Denso 52 pin conector, which is the same as the 3FE ECU. This allows me to use the 3FE engine harness. The wide band O2 sensor/controller wil allow the MS to self tune. It will also support me using Supra injectors.
Replacing the wimpy 210 cc/min with these 315 cc/min 7MGE injectors.
