That looks great! Better than a sand blast cabinet.
I'm gonna send you some stuff of mine to clean up!
No problem. Send it over, but I don't think you're going to like my hourly rate.That looks great! Better than a sand blast cabinet.
Thanks, I'll look it up.@GA Architect did his frame as well as several others. I would check out his thread
Awesome explanation! I'm falling to below 10 psi on my gauge when warmed up. The low end of my manual gauge is hard to read since it's purposed for efi fuel pressure, but it's under 10 above 0.Keep in mind that "normal" oil pressure with hot oil on these engines is pretty low - it's a tractor engine. As long as it builds pressure with RPM you should be alright. Good rule of thumb is 10psi per 1000RPM - at least in the small block V8 world, seems to follow that the same logic would apply here. My small block, at idle on a hot day, is 12-15psi by a mechanical pressure gauge, and at or just below the lower hash mark on the FJ40 gauge. When I first start the engine with cold oil, I see 45-55psi depending on just how cold it is. On Chevy V8's, the "low oil pressure" warning light isn't even triggered until 6 or 8psi at idle. They really don't need much to keep things lubricated.
Once everything is hot, "normal" oil pressure hovers just under 20psi in the winter, and just under 15psi on hot summer days. At 2000 RPM I'm typically around 35psi. By 3000 RPM I'm at about 45psi. This is my second small block in this truck (replaced a 283 with a 350) and even with extremely worn bearings in the 283, the oil pressure was only marginally lower. (maybe 9-10 PSI at idle).
I've posted this on a couple of questions like this before - it's from the manual and a great reference that helped me put my mind at ease when I was going through similar:
Basically, as long as your oil pressure stays above the L at idle, you're probably fine. It will ALWAYS drop as it warms up. As for temperature - this is my more frequent battle since I'm trying to cool a V8 on the stock FJ40 radiator. It's sufficient, with a BIG fan, but barely. the third hash mark up the gauge is "only" 210F. On a hot summer day, my small block will start pushing north of that hash mark (215ish) but the radiator isn't going to boil over until 230-240 degrees, so until you start pegging the "H" you probably don't have anything to worry about.
I've confirmed the temperature gauge is accurate to the above with an IR thermometer at multiple points on a small block. so, while just north of the second hash mark is in that "perfect" 180 - 190 range, I don't worry if I'm pushing the third hash mark on a hot day. I start to worry if I climb much past it.
15w-40Ok sub 10 makes me a little nervous. If your bearing clearances are super wide it could run that way for years most likely but that’s a little close for comfort. What weight oil are you running?
My FJ came with 2 long jump seats (not installed). One is in better shape than the other but both need some work. Did a 76 come with the long jump seats and no rollbar?
I agree with there's a certain amount of risk no matter what. When I saw the 40 jump seats, I thought of the days we used to ride around in the back of my grandmothers station wagon. She had the two fold down jump seats in the very back. I was hoping to share some nostalgia with the kiddos just around town.Depends on what you're going for with this truck and who will be sitting in the back. Long jump-seats won't work with a stock roll bar. The short seats will - so theoretically having the roll bar and a shorter jump seat offers an added level of protection - though there's a lot of debate as to whether the stock roll-bar is really up to the task in a roll anyway...it's pretty thin metal.
If you'll have kids/car seats in the back, it's really tough to mount them to the jump seats safely - but I've seen it done.
At the end of the day - it's up to you! Long jump seats have a certain retro "cool" factor, short jump seats are period correct if you're a purist, and a rear bench is arguably safest - though my counter argument is if you're concerned about safety by modern standards you wouldn't be driving around in a FJ40 to begin with!
I've got a new cap and a 180 degree thermostat to try out. If I can't keep it up over 10 psi, bearings are next.Since I am spending some one else money why don't you role in a new set of bearings and see if that alone will increase your oil pressure. Mains and rods. Remove a rod and main bearing to see what size they are. This would give you an opportunity to put in a one piece pan gasket.
