Crawl should still work... though the system might get confused... not sure yet. I don't use the feature often, if ever, so not a huge concern.
I guess CRAWL would still work when the locker(s) are NOT engaged, but it would be impossible for CRAWL to brake one wheel on the axle when the lockers ARE engaged.
I think you may be confusing CRAWL with TRAC (or is it ATRAC on the 200 ... I cannot remember ... basically the traction control). They both are based upon braking, but CRAWL is closer to a low speed cruise control that modulates speed via brakes and/or throttle. The braking of individual wheels is the traction control system.
Easy to get crossed up since they are integrated and use the braking system.
Either that or I am totally confusedit has happened before and will again ..
I just got my 200 and can't wait to try out Crawl mode![]()
thanks for the heads up on that, so the speed is controlled by the switch on the center consol, correct? how do you do the terrain select?
