I have the quarters repaired and have the sill and sill cover fit up. The sill has some thin primer-like coating that scratches of pretty easily, so that has to go.
My question is how others have preserved the metal that is between parts. Like the sill, under the tub floor and sill cover? I have used weld-through primer in the past, but I'm not convinced the powdery coating actually prevents the parts from rusting. I have seen in restoration forums people have recommended epoxy primer and just removing it from the locations of the plug welds, not going to burn too much primer back from the welds?. How do fellow Mudders do it?
I blasted the inside of the new sill. Looks to be a prep problem with adhesion for the primer that came on it. It is really tough in many areas but flaked off in others. If it was done right it could have saved me a lot of work.
