Just curious Mark:
have you put on a spartan locker on an 80? Have you driven an 80 with one on?
I daily drive an fzj80 with a spartan rear locker all year through winter. Yes, has some quirks that are mostly unnoticeable.
I don't regret my investment- You will need gaskets: for the axles and the diff, and I'd get some new hardware- conewashers etc just in case you loose some or youneed htme.
I have driven all of the auto lockers out there in a number of different rigs, most of which I have owned and driven routinely, including 40s, 45s, 55s, 60/62s and yes, 80s too. Even Mini-trucks and Tacomas.
I have for years and I continue to. I have not had a Spartan in a rig I personally own. For the reasons I have already mentioned. But I have installed and driven them too. I don't think I have put a spartan in any of my rigs... maybe I did put on in the front end of one of the trail rigs once. Not sure right now. Anyway...
I have nothing against auto lockers in general. I am actually a big fan. They are tougher than many think when used in a Cruiser diff, and do a great job in most applications. Back when Detroit first brought out their "EZ Locker" version they did have some problems (I sent a batch of five back to the factory once they acknowledged the problems) but they solved that.
I am not an overly picky wannabe that is concerned about the quirks of an autolocker in most rigs.
BTW, I (and others) have found that Toyota full floating axles with autolocker installed tend to suffer loosened hub nuts much more often than axles with any other (or no) locker. We have attributed it to the constant shock (small but constant) of the locking/unlocking action. Like tapping on everything with a ball peen hammer. Eventually the vibrations have an effect. I apply a small amount of medium strength locktight to the studs and nuts if I put an autolocker in an FF rear axle. And make sure to torque the studs to spec before putting the nuts on. You do not want those working loose. Once one does the others follow quickly and broken studs come fast.
For me, the autolocker characteristic that I will not accept specifically in an '80 series, is the loss of constant equal differentiation and equal torque loading to the wheels. For me, as well as for most people driving '80 series they are not dedicated trail rigs. The primary use of my '80s are as road rigs. Yep, mine see more trail miles than most, but I still see a lot more road miles with them than trail miles. All year long, all conditions road miles.
If you actually use the rig in higher speed, low traction conditions where the "all wheel drive" aspect matters (Running down snowy highways like the ones I have to deal with right now after about 18 inches of wet snow yesterday or the bare ice that often covers the outlying highways all winter around here) then you really really really want all four wheels to be able to deliver equal power to the pavement without any of them being forced to scrub or skid going through a curve or having only one tire on the rear pushing as the other freewheels around the outside path.
That gives you a much larger envelope of safe operating parameters and keeps you on the road and on your way where you might very well have been in the ditch and on your lid without that ability to maintain full available traction. It has made a difference for me a more than few times over the years .
Does an autolocker make an '80 unsafe? Absolutely not. Does it reduce it's performance capabilities? Yes it does. I chose not to accept that reduction.
Mark...
