I've got a '72 F-155 engine that's been completely rebuilt with new pistons, rings, cam, lifters, bearings, seals, and gaskets. I've even added a few improvements such as 2F valve cover, power steering, throttle body fuel injection, ceramic coated header, and electronic ignition to name a few. That's it in the first picture. Perdy, Huh?
I'm getting ready to fire it up for the first time and decided to prime the oil system before I set the distributor. To do this I used a tool I made to spin the oil pump using a cordless drill.
I removed the valve cover so I can see the oil come out of the rocker arms and then fired up the drill. Unfortunately, after several minutes of spinning the oil pump I got no oil at the rocker arms. None. Nada. Zilch. I got pissed is what I got!
After a few moments commenting to the engine about the questionable marital status of its parents at the time of its birth, I decided to check the oil filter to see what was going on over there. An attempt to remove the externally mounted spin-on filter revealed it was full of fresh clean oil. Thus confirming the pump was indeed pumping (So, I have that going for me. Which is nice!).
For those unfamiliar with the F's oil system, here's the Reader's Digest version: From the pump the oil takes one of two paths. Some goes through the (externally mounted) oil pressure regulator to the oil filter and then straignt back to the oil pan (via two external oil lines). The other path is directly to all the various internal pieces and parts (crank/cam bearings, timing gears, lifters, rockers, etc.).
In order to get the oil up to the rocker shaft and rocker arms, the oil must travel via a little copper tube from the block, through the head, and into the rocker tube. That tube is shown in the second and third pictures.
I have since ensured that (1) that little copper tube is clean and free of obstructions and (2) properly installed.
So, with all that being said, anyone got any ideas as to why I'm not getting any oil pressure on the top end? I sure hope so, cuz I'm all out.
Steve
Steve
