Power window switch part#
Illinois
My driver door power window switch has been acting a little funky so I took it apart to see what was going on and the little white plastic "forks" that go between the spring and rocker switch are all broken. Does anyone have a part number or source for them? No luck on google.
Odd question, can you use the newer model switch assembly to gain auto down function for all windows on a 99?
I'm assuming a parts switch is going to be the answer but I wanted to try getting new pieces if at all possible first. The ones in whatever switch I get are going to be just as old as mine.
I was able to purchase a replacement master switch panel on Amazon for less than $100.
I went to the junkyard today to look for some and opened up a million power window switches from various Toyota models and none of them use the same parts. Not sure what I'm missing here. Called the Lexus dealer and they want over $800 for a new assembly.
I've been running one of Electric Power Master Window Control Switch 84820-60100 For Lexus LX470 98-02 from eBay for months. It has automatic LX features. My old switch didn't have full functionality. I left the window down one day and it filled up with water. They don't like to be submerged in water. I ordered a 2nd switch since they are under $30. I used compressed air to blow out the water. Before the replacement switch arrived, the 1st switch dried out and started working again. I haven't looked back.
Just to clarify, the auto up and down works on all windows? That was my hesitation with trying one of the cheaper non-oem switches, I see conflicting info on whether they do it on all or just the driver window like the land cruiser switch.
Auto up and down for all windows. It even has the little green lights on the buttons. I gained that functionality with the replacement. The switch it had when I bought it only worked for the driver's window. It was a pleasant surprise when everything started working. The driver's motor had failed and I replaced it and the regulator about a month before getting the switch. With the driver's regulator working smoothly, the auto-up function works without issue.
Hmm good to know about the auto up in the
Lx.
Ordered that one and it works great, thank you for the advice!
Thanks for letting us know. Good to see a problem solved for about the cost of a deluxe pizza dinner.
I’ve got an eBay special one for testing. Always works fine.
Doesn’t have the auto up feature though
I bought a third party (Chinese, I think) DS switch, and it drained my battery twice before my mech figured it out.
You may want to hang on to your original switch. I ordered one off eBay and it was good for a couple months before it started acting funky. I ended up taking the eBay switch apart and putting the little white rocker thing in my original switch. It was a little different design but it worked in the original switch. I kept the other 3 for spares. Original works great now.
How is the switch assembly holding up after 8 months? Looking to order one, but will see how yours is holding up before I order. Thanks!
Perfectly! No complaints.
