Power window switch part#
Great!! Thanks for the quick reply. Got mine ordered.
I think the old switch that was in mine before the replacement was for an LC. I gained functionality with this LX unit with button lights and auto up and down.
I ordered an aftermarket replacement switch for our LX and nothing but negative issues. Caused problems for other items on that circuit.
So, I ordered a factory master switch from Impex. All is right again.
Got the switch installed and works perfectly. The lights in the buttons is a nice touch.
Great! This is one time when I was glad to see additional lights. 👍
I have just received my power window switch from Amazon.ca
HDJ100 1999 OEM p/n : 84820-60110 EMIAOTO Power Window Switch Button Auto Switches Window Lifter Switch 84820-12340 84820-60110, Interior Switches - Amazon Canada - https://www.amazon.ca/dp/B09JZBNC2V?_encoding=UTF8&psc=1&ref_=cm_sw_r_cp_ud_dp_0QM77WJ8SP2RHJM7ZX0E
Auto UP and DOWN work.
EDIT : I had to use a Dremel to remove some plastic underneath the panel (switch panel) to make it fit. Door lock and Window lock buttons are slightly smaller so there tiny gap around
Hi Josie-is that switch from Amazon still working good for you? I am about to pull the trigger on it since mine is crapped out. Thanks.
Yes no issues with the aftermarket switch panel.
I ordered the switch that Josie recommended off Amazon. The drivers window will only work if the smaller electrical plug is not plugged in.
What is that plug for? I couldn't figure it out. See below photo for context of the plug in I am talking about.
Thanks
