I meant one of the setups that do all tires at once; you have the big cfm now to support it.
Though the idea of quad pumps does sound pretty cool
I went down the left (US driver) side along the firewall and behind the exhaust shielding, and then continued behind the shielding underneath. Was able to put the whole run in using existing shielding and fittings. I used a braided stainless teflon tubing, which I wouldn't do again. Plain on PTC tube would be so much easier to terminate and if you get a hole after 10 years pretty easy to fix too.Can you provide some guidance on exactly how you ran the air line to the rear? I’m trying to figure out the best path and what I should avoid.
Really enjoyed this mod after filling tires like 8 times last off-road campout. Real time and effort saved, even airing down lower knowing I can air up fast. Well, between resetting the breaker.
I had a 50amp resettable breaker with my original single pump, that turned out to not be enough margin especially when everything is heat soaked. Fortunately it's resettable and had to reset on longer inflates. Replaced with an 80amp.
Rear tailgate port also was pretty big from a convenience standpoint. Still useful to have a front port for the couple times I wanted to use an air nozzle to blow dirt/dust off the rear hatch for car camping.
So do you still have your engine bay covers in place? Or does that area at the front passenger side get enough ventilation that it isn't a problem? And where are your intake filters at? Did you leave them right on the intake valve or?
I have a 400C that has been sitting in my garage and I am considering either this location or possibly mounted oboe the spare tire bracket on the drivers side. There is enough room there to mount it and it seems like a good location, but that dead space up front may be too easy to pass up.
Yes, to covers in place. They're important IMO, with the forward portions, to guide airflow and maximize radiator performance.
Compressor filters are directly on the pump snout. There's a couple good cutouts to the fender that they probably get reasonable airflow and air there. I find the Viairs to be less stressed designs so I'm not particularly worried cooling and airflow.
The 400C is a great pump. More compact and faster for tire pressures. I think you'll find good space to install there.
Great. Thank you. And you just T-ed it and kept your original quick connect up front?
What do y’all think is the right unit for my 33s in that PS resi location?
I am having trouble finding a good portable 12V compressor and the rear outlet is limited to 100W anyway for anything AC.
Im thinking either that or build in an actually useful 1000W inverter for the rear and pull electrical vs air cables back there. The way I figure i need power for everything anyway and the front passenger spot would be a second redundant battery power supply.
A single Viair 400C would handle 33s with ease
Amazon product ASIN B000FQ78TU
You'll need a few additional accessories to round things out. Reference here
I have a 400c in this location and am planning on upgrading. The 400c is a workhorse and does the job without complaint, but it is fairly slow to take me from 18 up to 36 PSI with my Morflate. I am actually wondering if a 450C would fit there.
Very nice! I would suggest as a small upgrade, using an MS21919 Adel clamp instead of the modified hose clamp.Having done a power steering relocation mod recently for a yet to be completed twinz project, thought this would be useful for others on how to create a simple and effective relocation bracket. I know others have needed to relocate the PS for other reasons, including fitting dual batts.
Here's the relocation position. This is probably as simple as it gets, as there's no need for any re-plumbing or cracking open the PS circuit for that matter. Plumbing elbows and clearance fits like a glove in this position while also maintaining rubber isolation. Using an unused mounting ear off the radiator.
Remove PS tripod bracket from fender and PS resevoir.
Two major fab steps. One inner fender modification.
1) Modify bracket by cutting it in half, preserving this half of the bracket with one foot and the reservoir holder upright
2) Create a band clamp with a mounting ear and hole large enough for an M8 bolt. I used a 4" band clamp I had around in the garage, but it was longer than I needed so possibly a 3" one could work? Best with a 4" as it's easy enough to cut off excess. Bend and fold a mounting ear into the band. Though want to mock and bend once so as not to fatigue break the strap. It should fold easily in a vice or pliers.
3) Use aluminum stock to make a bracket extension from existing hole to partial tripod bracket. Or drill and tap hole directly in fender which should work. I mounted to flat stock that also integrates to the rest of my project.
MS21919 DG / WDG Clamps | Aircraft Spruce ®
MS21919 DG / WDG Clamps Loop-type cushioned aluminum alloy clamp. Cushion (non-fuel resistant) is bonded to inner surface and edges of clamp. Cushion assures tight fit and eliminates ...www.aircraftspruce.com
You're in a big 34" tire with 17" wheels so that definitely gets into tire volume that a single compressor will struggle with. Just as I found going from 33s to 35s, and when I upgraded from single to twin compressor. Good info and may be something for @AnyMal to consider depending on his tire size goal.
Interestingly, the 400C is 30%+ faster than the 450C for pressures relevant to tires. It draws more amps. Trade is that it's not continuous duty, but that again doesn't matter for tire relevant pressures.
