I just skimmed here, so apologies if it's already been said, but get a real temperature gauge or use torque, scangauge or the like. The stock gauge is pretty much just an idiot light.
Lots of useful information. Thanks! I was going to start with thermostat but I’ll go for the clutch now based on this information. It is definitely not engaging as the rotation speed seems to be a low constant. I’ll take a look at the level in the radiator as well once she’s cooled down a bit. Thanks again!1) Looking under the oil cap for milky stuff tells you absolutely NOTHING about the head gasket condition. Period.
2) What is the level of coolant in the RADIATOR? (not the overflow tank)
3) I'll third the aspect of the fan clutch being the most likely culprit, other than not having enough coolant in it to begin with.
4) You may want to consider getting a TOYOTA radiator cap. I have seen MANY radiator caps that SUCK with quality and have had lots of issues because of it. Not to say the Toyota caps are not 100% problem-free, but they do seem to have better overall quality and longevity.
5) The fan is "always on" because it is driven mechanically. It is whether or not the internal clutch engages and makes it ock up together to match the pulley speeds, hence the term "fan clutch")
I don’t think the AC shuts off, but may be it just hasn’t gotten hot enough yet. I will keep an eye out for that. There is a definite lack of fan noise and I will replace the clutch as a first step.If your truck is a later FZ with ODBII then you should get the following setup so that you can actually see what your coolant temps are:
Any odb2 bluetooth sender that is compatible with your smartphone. I got a similar unit for a similar price that works great:
Amazon product ASIN B00PJPHEBO
Any App on your phone that will read the output from that ODB2 sender. I purchased and installed "Torque" on my Android phone and it works great. You can then watch your temps and know what's actually going on.
If your's is odb1 then the easiest option may be a cheap Infrared temp gun though those are harder to use and can vary based on where you shoot etc.
Beyond knowing the actual engine temps another clue on overheating is that if you hit a high enough temp your 80s AC will shut off. Often this is an early/first clue that the engine is getting too hot. If your AC has been shutting down when your engine temps are up then this could be a big clue that you are actually running warm. Read up on this forum for info about what temp the AC cutoff happens at.
If your rad is fairly clean and the truck runs well overall but is running warm I'd be looking closely at the fan clutch.
Will do. My truck is a 95 so I don’t think I have the OBDII setup, but I’ll confirm the temperature independently.I just skimmed here, so apologies if it's already been said, but get a real temperature gauge or use torque, scangauge or the like. The stock gauge is pretty much just an idiot light.
Copy. Thanks!I recommend figuring out the actual temps as a next/first step. Then you'll have a baseline for evaluating any/all changes that you make.
It is indeed! Just confirmed.95 is obd2
OBD II conformed! Picking up a scanner this evening to go with the app. I checked up prices and my local dealer has the clutch at around $200. The power clutch you are referring to has great reviews, but is around $275 shipped. I am unabashedly quite poor so I most likely will stick with Toyota clutch. The swap seems simple enough so I’ll attempt it as soon as the part comes in.This is what i would do:
1) if you are going to get a new fan clutch, get the blue clutch and upgrade clutch fluid
2) while you have the clutch out, take time to reseal (gap) between radiator and shroud
3) install real time coolant temp gauge. Koso or OBD II scanner. This is by far the best mod. and you will see never to trust the stock gauge after.
4) install a new radiator cap (OEM)
My temp is 180-187 F highway/traffic with AC on. 190 -195 F on long hill climbs.
best of luck and report back
Is that the identical Toyota part? If so God Bless you as it’s less than half the dealer price!Aisin fan clutch:
Fan Clutch at Amazon
If that isn't enough, you can change the silicone fluid yourself, it is both cheap and easy to do.
My '95 showed similar symptoms a couple summers back. I had already installed a new radiator, so I was a bit surprised to see the truck overheating on the first hot day of the year. My truck happened to have a blue hub fan clutch on it, so I replaced the fluid as is detailed in many threads here, and it did indeed take care of my problems.
And I will second the ELM bluetooth OBD2 adapter and the torque app. They showed me the real temps, which the stock temp gauge didn't even hint at until things were about to go south.
This is probably overdue- do a search on this forum for your issue, and for fan clutch mods. Lots of info you're not going to get from this thread.Is that the identical Toyota part? If so God Bless you as it’s less than half the dealer price!
I can definitely afford to replace at this price! Did you pull out the part to do the fluid swap? If so would you happen to know the torque spec on those 4 bolts? Anything else you could think of that I should be wary of?
Again thanks a bunch!
I will definitely consider all that. I think the fan clutch is dead though as it does not engage at all (fan is always spinning at a low constant speed). Thanks for advice!
