Ok - first , I am a novice and am learning my way around. So, please be patient
Bought a 78 with a 75 engine.
PO de-smogged it he also removed the charcoal canister..and the PO ripped out a lot of stuff
When the pig sits and drives the gas fumes are almost overwhelming
I dug into it and the hose at the top of the fuel separator (which I believe should go to the CC) was cut and just hangs underneath body. See pics
Inside the engine, no visible hoses for venting I can see
I do see two fuel lines one with a filter and one without that merge into one before the carb
I’ve searched many of the mud posts and I’m just still confused how to reinstall the canister With my situation. ...or should I just bring it to a mechanic (may be easier) . Even if I got a CC, I’m not sure how to hook it up since most of the smog stuff was removed by the PO.
Here are some pics
Like I mentioned above the gas smell in the engine bay and inside while driving makes eyes water sometimes so I need to get this fixed ASAP.
Help/advice would be greatly appreciated
Here are some pics
