Dozer18
Gents, hate to admit I've been lurking here for a while, but still learning the FJ62 and my Jeep CJ experience does little good here. In any case, I've learned a lot so far from all of you and hope to be of help in the near future.
In the meantime, I need to ask for your help. I've done many thorough searches of this forum but can't seem to pinpoint an answer to my problem. I'll start from the beginning:
Had my 3FE FJ62 (1988) for a couple months when, after parking at work one morning, notice that I have a rain forest of coolant coming from the engine. Try as I might, I can't see exactly where it's coming from. It drips down directly over the tie bar/sway rod area, but seems to be directed there. Anyway, I experiment a little, and it's doing it every time I run the engine (takes about 10 seconds to start leaking after a cold start) at first. So, after what I thought was thorough research, I determine that I have a bad water pump and proceed to replace it along with new belts and hoses (it has 240,000 miles on it and yes, I used OEM).
Now, many of you probably know the pain of installing a water pump, and now I do too (I did cut the shroud while it was out -- thanks for the tip!). Tried to reload the coolant system with antifreeze, but could only get it to take about 16 quarts vice the 20 or so the FSM states. Nonetheless, I fire it up, and there's no leak!! I was a very happy camper. However, when I started it the next morning, it started leaking like crazy again! The new water pump had absolutely no effect on the leak! So now I'm $400 and 6 hours of my life poorer and back on square one.
I decide to drive it around a little and find that it doesn't actually leak like a sieve every time I run the engine -- just most of the time. Also, the temp gauge is running at about 80% hot all the time -- traffic and freeway -- instead of the 40% or so it used to run at (never got those full 20 quarts in, and I burped it best I could). So, I take it to a local shop, and the boys there tell me I have a bad radiator. That may be so, but doesn't really explain the crazy leaking to me. That said, it may not have leaked on those boys at all. So I pick it up from the shop, and when the guy drives it around for me he tells me in a whisper that I should check the thermostat -- like he didn't want the others to hear. OK, but still doesn't explain the leak I can't completely see. And that's where I am now.
Sorry the post is so long, but wanted to get all the info out there. The leak is definitely coming from the front area of the engine block, but I just can't tell from where. When it leaks, it's like a garden hose, not like a trickle. Does it about every other time I drive it or start it, but the temp gauge runs pretty hot regardless of whether it's leaking. Can anyone help me? I want to get my baby back on the road. Thanks in advance,
Brandon
Brandon
