- Thread starter
- #121
Idler pulley and PS pump
So, below is what my idler pulley looked like
Had to order a new pulley from Toyota, the new ones are not rebuildable so hang on to your old ones.
See here
I am going to order a spare bearing from somewhere and then rebuild my old one.
and here is repair in process
This was a real bear as I did not pull my plates off the bottom of the engine. Figured it would take too much time that way.
See here
helped me with running the starter (EFI fuse pulled) and turning wheel while I poured in fluid. note the new fluid (red) draining out in the bypass i created.
one of the sprinkler pipes busted which ends up causing no water pressure in the house.
