I hope to soon have a cheaked-plate dash! god I love them!
so will you be using the shift lever or do you have a floor shift? i have a Muncie 4psd so do not need the column shift. I like the looks and could see myself going that direction too..thanks for adding the link, was helpful. what else do i need to complete this swap if i were to order this??
going in my '64
So are autometer gauges all electric, so you can use the existing wiring from the sending units to power them?
How does the speedo hook up? Isn't made for a domestic vehicle?
OK, this is my dash I made out of .25" aluminum. I used hole saws and a drill press to cut all the holes. The panel has green leds for the turn signals and a blue for the high beams. It is painted with high metallic silver base coat and then cleared to match all my other silver pieces in the 40. It is populated with VDO gauges.
If you go to my build thread.....and search threw 4 pages..... ah f-it, here ya go.
I remember reading about this one - from memory it's just a sheet of ply or steel (i can't remeberThis is my favorite setup that I have seen here on MUD. It's not mine, but I would love to see a write up on it..
) with a bead of sealer around the edges.
