- Thread starter
- #41
I removed the engine block plug, drained and flushed
Not difficult
Not difficult
I was not able to bypass it with the metal tube still in position connected by the brackets. Once you get the metal tube off, I removed the top bolt and broke the bottom bracket, it's just as easy to put the metal tube back in as it is to bypass.I chose to reuse the metal tube. Others choose to bypass. I like to keep things as close to OEM as I can when it makes sense, so chose that option here. Bypassing the tube is definitely the easier route and those that do it that way have no complaints
Pinhead has great instructions on this, which I followed. Take the driver side front tire off, then lower the axle down onto jackstands, then you can actually sit in the wheel well with your back against the brake caliper and reach everything with your left hand.I'm about to attempt this job for the first time. Going to do all the heater hoses and PHH, heater valve, thermostat, water pump, fan clutch and both belts. Does the truck need to be jacked up to work on those items?
grab and twist back and fourth and the bracket will break off.bumping for clarification...
is the bracket that you guys are breaking the one in pic #7?
Drove from Nor Cal to Phoenix to Baja. No seepage , if I had enough time I would have ordered from Witt, however the hose let lose day before we left on tripHave the clamps been on for awhile, seen any seepage?
