alia176 said:Wow, that's some serious oil! Perhaps this is why the "catch can" on Ebay are a much larger in size. Any easy to way to plumb this back in to the system some how?
RavenTai said:no way woudl I plumb this back into the engine, I was expecting it to contain some water, I was not expection so much that I could see it, it also smelled of partialy burnt fuel and was much darker than what was in the pan
alia176 said:Sorry guys, didn't get to see the TRD separator while the link was alive. Does it look like other ones in EBAY or was it a special looking item? Can this be purchased from our usual outlets for the usual (smart shopper) price?
Thanks.
Ali
turbocruiser said:Well, I got that TRD catch container and at first I thought it was ridiculously large but now I'm starting to understand why. I also wonder whether it is really something made by or authorized by Toyota; it looks like Japanese tuner market stuff but I cant tell who really makes it. Anyway, might have to take a more serious look at the thing now.
I want fawking pictures, I really thought long and hard and almost bought one......... post some pics please...............need to see, oh fawk it, probably gonna order one, functionality and bling
............doesn't' make me a princess .................
reffug said:Did you really get one of those bro?I want fawking pictures, I really thought long and hard and almost bought one......... post some pics please...............need to see, oh fawk it, probably gonna order one, functionality and bling
RavenTai said:turbocruiser, yours looks similar to this correct? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7934073673&category=46098
What is inside those? Is it just a chamber? Or is there something else inside to help separate the gas and liquid? Do the inlet and outlet just dump into the changer and that’s it?
Could you pop the top off and take a pic? I wonder if the are more or less effective as the mini water separator?
I am going to run the small one for now and see if I dislike the during-fill-up draining enough to pony up $40-$50 for a larger one
RavenTai said:Since it has turned cold mine has been collecting a lot of water, I also started car-pooling so a lot of short trips. Hard to tell how much oil, I need to go to a larger one. It fills full of milky water/oil mix about every other fill-up. Would be nice to only have to empty it at every oil change (5K) I
landtoy80 said:Raven, have you tried and hooked it up to PCV hose #2 to see if you get any oil?
I need to get two catchers as I have oil sucking in hose#2.
It must suck from #2 and #1 untill all the air is removed then #1 takes over and #2 is a vent OR there is something wrong with my motor.
turbocruiser said:Holy Moly!!! That much water? I'm rethinking if this is the way I want to go...I still have that "TRD" oil catch can which probably has a .5 liter capacity but I have really resisted putting it on cause it is all chromed up and cause i am sure that it is indeed fake TRD, but from the Japanese market for sure so who knows??? I was going to go with the mini-separators but now I'm wondering??? The other thing I'm wondering is where to put the thing; I know the traditional way is between the pcv and the thottle body but i think in my case i should really put it between the open port of the valve cover and the open port of the air intake hose (see pic please). The reason for this is that in the intake hoses going from the air filter area to the turbo, there is oil residue, I cleaned it all out about four thousand miles ago, but on last look there was probably about another 1/4 teaspoon of oil at the bottom of the tube just before the turbo. Now maybe it’s a good thing to keep the turbo misted by fresh Mobil 1, but I would think it is actually just another contaminant as far as the turbo is concerned? Anyway, if i can catch the oil there, my intake system and intercooler system would stay so much cleaner. For whatever reason, my TB never seems seriously dirty, and, it is so much easier to clean than the intercooler would be. Any thoughts on this? Also any thoughts on if the incredible amount of water Raven is retrieving is what all our engines are dealing with anyway, or if there is something specifically about all separators which increase the condensation in there - closed glas chamber sweating on heat up and cool downs??? Just seems like a lot of water to me? Thanks.![]()
Darwood said:Considering how much crap the EGR puts into the intake I would say only the forced induction guys would ever need a catch can to keep the gunk out of their turbines. Naturally aspirated engines need not apply.
landtoy80 said:Is there really any thing wrong with oil crap going into the intake chamber, manifold, valves, cylinders etc?
The main reason I want the catch tank is to see how much oil the motor really uses.
I use 1 qt per 1800 mi with RotellaT syn.
Right now I can't tell how much the motor is buning and how much is being sucked by the pcv.
