PCV inline oil separator.....
Darwood said:
Kurt, were your EGR ports clogged with oil? When mine were clogged it definitely was due to EGR carbon.
The port that was plugged was on the throttle body, the one that runs to the modulator port R i think. I guess carbon could of got in there or oil could of flowed over the port and plugged it???
I will find out when I remove the throttle body.
That will be interesting to see. Keep us updated :cheers:
Went back to the stock setup today,
the mini filter fills up quickly and I could not drain it where it was mounted, so I was not getting to it in time and the oil/water is going into the intake and fouling it anyway, spent some time considering enlarging it but no easy path and a lot of other things to do right now.
Maybe I’ll make a second try at it later,
BTW the shaped OEM PCV #2 hose from Dan fits a lot better and don’t chafe on the hood like bulk ½ hose does, the pair of hoses was ~$20.
