I have water that comes down the black 'rubber' topped insulation on the firewall, as well as thru the AC blower housing. Based on other threads, I believe that the 'stovepipe' above the blower, that sits in the cowl, with a mesh screen on top, is leaking at the base, where it meets the bottom surface of the cowl space - as opposed to the top surface which has the slots and wiper shafts penetrating. I have been considering getting one of those ~$100-150 scopes that I could insert thru the wiper motor opening, to inspect that joint around the perimeter of the stovepipe. Then I have to figure out how to get in there to patch, short of cutting it open...
It leaks in heavy rain, as well as going thru the car wash - but not until the blowers hit the hood/cowl, pushing soapy water on to the floor board. You should pull the large black plastic plug in the picture out - I found rust on the sheet metal that is behind that and treated it.
