Passenger floor board water I know, I know!
Want to come back to this topic with two questions since I am facing the same issues:
1. Is there an FSM for fender removal or other body panels? I have the engine, chassis, etc., but haven't seen one for that type of work.
2. I saw in other threads there is talk of fishing a wire through a drain that can become clogged? Not sure where to find this and attempt it before I take my whole passenger side fender off to inspect behind it.
Take the chrome/plastic louver(there is a actual name for it that escapes me) off, and you should see a black plastic tube toward the door, on either side , with a slight kink to it, held in place by a flexible metal tab. Take it out, and the metal connector at the top of the tube is what can get clogged.
I need to do this exact same thing. I get water on both sides front floor boards. Appreciate all the pics and folks knowledge here very much.
Same here. I had no idea I had a leak until I started removing the interior for my build. I pulled up all the carpeting while stripping the interior and sure enough, the jute mat at both front floorboards was wet, and it was at least 4-5 days since I washed the cruiser before parking it in the garage. Item number 498345 to take care of on my build.
Hello It's Karl First Post! 2nd day with 94 . Floorboards wet so figure Sunroof.
I cut a 30 inch by 52 inch clear paint protection skin and applied to sunroof. I was just on the rear humps behnd sunroof and I was an inch from windshield. Will post results. I still see how water pools in Sunroof. I am thinking of shimming roof up .YES I Know It is a Super Genius Idea. Goto your Local paint protection get a pice applied. $100 tops. Kind of stuff you do when you need the fix and ain't got time for more damage. Nice to be here!
