- Joined
- Jan 6, 2012
- Threads
- 342
- Messages
- 10,987
I probably would not drill through the roof. I would probably run it down the a pillar instead in a clean way of some sort. I've avoided light bars on the roof because I've heard the glare is bad
Okay this Scanstrut stuff about has me sold. Which means, as some have suggested, that--like it or not--those connectors are just gonna hafta stay on the roof. So, Bonus Question:
Is anyone aware of some kind of slick little aerodynamic watertight housing that can stick on the roof (without admitting water underneath) and provide a home for those connectors and the leftover wiring? Maybe something teardrop-shaped, gasketed lid, with a hole at the back for the wire bundle...
Come now, don't mince words; tell us what you really think!This?
Personally, I'd avoid it like the plague.
I'd avoid making a hole in the roof like the plague in general though.
That cable port ^^^ is relying on either the gasket supplied ( would not trust) or sealant.
The gasket is quite narrow under the edges at the large hole.
You're relying on grip strength of self- tappers through sheet metal to compress a rubber?? gasket adequately to permanently seal. Not great IMO.
Unless you punch screw holes through the roof (which will distort the roof panel), as you tap screws into sheet metal, the threads will pull the roof metal up around the screw making it even harder to get that rubber to seal.
Movement and vibration will cause the rubber to fret, letting water find it's way under the rubber.
Eventually screws will rust, or roof panel will rust, or screws will lose tension letting the gasket leak.
My 2c
forum.ih8mud.com
Come now, don't mince words; tell us what you really think!![]()
Another thing to consider is how many wires you actually require running to the roof…
In theory, you only need one single 12v (ground could potentially be picked up through the rack itself.
Then just run a remote Bluetooth relay transmission box (so signals can be sent remotely).
Then it’s just a matter of coming up with an elegant black wire which should be much harder to see… and makes the connector choices much simplier
Or alternatively, put a decent sized lithium battery and solar panel on the roof, depending on your usage might not need any wires lol
No man, bring it on! Seriously. What are your thoughts on the vent-frame mount from the other thread?Sorry for the cynicism. I've been paid a lot of money over the years to fix leaks with all sorts of IP rated fittings, and various penetrations through metal roofs
I used to work building caravans. We used a crazy amount of silicon and sika to keep those things water tight, and just as much again when they came back 12 months later with water ingress problems.Sorry for the cynicism. I've been paid a lot of money over the years to fix leaks with all sorts of IP rated fittings, and various penetrations through metal roofs
These Scanstruts in particular, or supposedly watertight fittings in general?I used to work building caravans. We used a crazy amount of silicon and sika to keep those things water tight, and just as much again when they came back 12 months later with water ingress problems.
Sorry, didn't mean to scare you off the idea, the problems were mostly from poor fitment. Loads of sealant applied poorly was the issue, only takes a pinhole gap to cause problems in those vans so sealing stuff as quickly as possible to boost production numbers just bit us in the arse later. Take your time and seal it all up thoroughly, should be fine, can check for water ingress with a hose.These Scanstruts in particular, or supposedly watertight fittings in general?
Unless you swap it out before that happens.Constant expansion and contraction of varying degrees because of differing materials. Odds are high you’ll have a leak at some point no matter what you use.
I don’t get back into 80s tech forum as frequently now, so just saw this thread.Come now, don't mince words; tell us what you really think!
Agree that going through the roof is problematical; until folks pointed this option (below) out, I just saw no choice. Now I'm thinking to run it through the vent housing, as shown in the thread below. 'Possibly' inverted, with a U-bend in the cable before entry to shed any water that might otherwise (one day) follow the cable into the housing. If I wanted to go through the roof, I'd use the one that Joey's been using (also in the thread below). If it's good enough for him...
Solar Wire Pass-Thru -Scanstrut Cable Gland
Finally got rid of my temporary solar wire setup and used a Scanstrut cable gland to get the wire into the truck. DS-H10-BLK Horizontal Cable Seal Power Boat - https://www.scanstrut.com/marine/power-boat/cable-seal/horizontal/ds-h10-blk All the penetrations are through the RR window vent. If...forum.ih8mud.com
Hey, thanks for the update. You get salt air, or too far away? Inset in the rack--so you can use the rack with the panel in place?I don’t get back into 80s tech forum as frequently now, so just saw this thread.
Update on my Scanstrut installation - I’m at well over 100 high pressure automated car washes (with brushes), numerous power washing/ heavy rains, and still no leaks or loose wires. The brushes pass right over the solar wiring and never snag the harness.
I am also of the mind that the only thing electrical that needs to be on my rack is the solar panel. The panel sits inset into the rack and the wiring is nearly invisible unless you are looking for it. Other than the fact that it is a LC, there is nothing flashy to attract attention.
Occasionally at the coast but no regular salt exposure.Hey, thanks for the update. You get salt air, or too far away? Inset in the rack--so you can use the rack with the panel in place?
Never thought of that. What rack are you running? Thanks again.Occasionally at the coast but no regular salt exposure.
Yes. The panel sits below the rack rails so there is full use of the rack if you need it.
forum.ih8mud.com
