Fixed.Thanks! I'll have to take a look at that in daylight. Second link above is dead.
I wrote: "I'll have to take a look at that in daylight."Fixed.
Can you think of anything that might serve as a stiff guide, enclosing the wire bundle just at that point where it passes the hatch edge?
What color? Seems like a simple question, but... Do you mean where the clear coat is still intact, or where it's not? Paint job will be part of the makeover--but first things first. Yeah, will def need something prettier down the road, but it looks like these will do for initial routing. I wonder if there's room for connectors in that strut-space, so the QP entry point can remain sealed all the time and not be messed with. Damn, it's 3am, I'd better be off... Thanks again!![]()
100 Pack Self Adhesive Cable Tie Mounts 3.6mm x 19mm SAMB19
These adhesive cable tie mounts are the perfect partner for our cable ties. Simply stick them to a surface, and pull a cable tie through to open up heaps more installation options!www.selby.com.au
Cable ties are easily removed/replaced, tie the bastard down tight enough near the top and you should be able to aim the wires in such a way that they'll clear everything when you open & close the hatch. More of them the whole way down, not the prettiest but they're removable later. What colour is the car?
And others who in general have forgotten more about this stuff than I'll ever know...
Can you think of a fitting that meets the following needs? I'm thinking aerospace or marine applications, maybe...
Pass-through from dry interior to exposed exterior.
Waterproof seals inside and out.
Exterior portion waterproof when closed (probably screw-type closure).
Exterior portion is fat enough to house a large computer mouse cut in half.
The pass-through portion can (and probably should) be thinner than the fat portion just mentioned; maybe the width of a finger or two.
Maybe a gland nut on the interior--in addition to (and below) the sealing fastener.
Flat or domed top cap.
So the outside is basically a small cup with a screw-on lid, and a smaller hole in the bottom that goes through to the interior. Ideally it can take a hit without ripping out, tearing metal, or breaking the waterproof seal.
Anything come to mind?
Good points, but I want the wiring as close to invisible as possible.
This?
You are over thinking this whole process.
In reality, you will probably not remove the rack very often.
Your light wire bundle, from the rack, could come down the A pillar. The connector could be attached to the cowl vent. Yes you put a hole in the cowl vent. But it’s not into the passenger compartment. And the cowl vent could easily be replaced vs welding up or patching a hole on the passenger compartment of the body.
Nice find.Seen these?
Yeah I can see opening that up, making it bigger and using that. Question is--how much bigger to accommodate connectors. And then I have to fish them all through that hole every time. If I didn't want the quick-disc, though, that would be perfect!If you're worried about getting power from inside the truck to the roof, Toyota already did that. It's in the liftgate. Open it and look up. As far as sealing the connectors when they're unplugged, just about all cannon plugs have waterproof caps, secured with a rubber ring around the plug.
Pics?slightly different requirements but the cables from my solar panel on the roof rack run through simple cable glands. It works really well.
Funny. But...let's say Joey wanted to light up his life with a part-time roof rack. "Industry standard" would be right out the window...
forum.ih8mud.com
Ha, excellent find! As to going in through the vent housing, on the one hand I like it, on the other it's more visible/snagable and--of greater concern--if it leaks, it is (so far as I can see) a potential hazard to everything on the QPM. Water is channeled directly at the wire entry. Then there are those pesky connectors... Very neat products, though; lemme think about that...![]()
Solar Wire Pass-Thru -Scanstrut Cable Gland
Finally got rid of my temporary solar wire setup and used a Scanstrut cable gland to get the wire into the truck. DS-H10-BLK Horizontal Cable Seal Power Boat - https://www.scanstrut.com/marine/power-boat/cable-seal/horizontal/ds-h10-blk All the penetrations are through the RR window vent. If...forum.ih8mud.com
Basically a less flash version of the scanstrut products linked above. These are used extensively in industrial applications. Came across them when I was working in environmental monitoring, used them lots to seal cable entrances to data logger housings etc. They’re cheap, easy to install and seal really well.Pics?
Well for the record and posterity’s sake—what are they?Basically a less flash version of the scanstrut products linked above. These are used extensively in industrial applications. Came across them when I was working in environmental monitoring, used them lots to seal cable entrances to data logger housings etc. They’re cheap, easy to install and seal really well.
Well for the record and posterity’s sale—what are they?
