joker2040 said:I don't have the Marks adapter kit but I am running in 2wd. My rig isn't a DD so I installed some hubs and run them unlocked while having the center diff locked. The truck certainly handles different in 2wd and took some getting used to. The only reason I went this route is because I installed a front Aussie Locker and didn't want to have to worry with it on pavement. When on the trail I simply lock the hubs and I'm good to go.
The only way I thought to do it on the cheap was to run hubs and no front drive shaft...
Wouldn't this still spin everything up front? Without the VC adaptor it would still spin the front drive shaft. The only way I thought to do it on the cheap was to run hubs and no front drive shaft...
While this is true that everything is still rotating, his goal is to avoid the steering manners of the lunchbox locker in the front axle when he is not off road. I tested this theory out on my Piggy a long time ago. Left the hubs locked, but drove in 2wd in town. It is annoying especially on sharp turns. JohnWouldn't this still spin everything up front? Without the VC adaptor it would still spin the front drive shaft. The only way I thought to do it on the cheap was to run hubs and no front drive shaft...
The big con for many if I am not mistaken is the loss of ABS. Don't you lose the ability to run 4-hi on the road too?
I really dont see the point making it 2wd, our 80 are designed to be 4wd and all of its components.
I really dont see the point making it 2wd, our 80 are designed to be 4wd and all of its components. Some say it takes some load off the front parts but your putting all that load in the rear so whats the point? I have driven lots of part-time cruisers back home in Venezuela and its not that I dont like it but if you have the advantage of a full time 4wd, why bother making it worse?
I feel the part-time 80's lighter to drive (turning, cornering,...) but that is just 80 with stock part-time kits, I have never driven a full-time converted into pt
As David said, this is just not correct. Many 80 came with a part time transfer case (HF1A) from the factory.
J
Can you buy a factory part time transfer case and just swap it in then add hubs ?
Depends on which tranny you are mating it up to.
The HF1A never came behind an A343F that we got here. It did come behind the A440F and the A442F as well as the manual trannies of the time period.
